Author Topic: thermostat housing bolt torque?  (Read 3822 times)
merrill
« on: November 07, 2006, 13:12:31 »
Hello all,
what is thermostat housing bolt torque?
thanks
matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: thermostat housing bolt torque?
« Reply #1 on: November 07, 2006, 18:11:01 »
Hello Matt,
You probably will not find this listed. It is not critical, standard metric hardware grade 8.8, I believe. It doesn't take a lot of torque to seal the rubber o ring here. Just be careful not to break them off. Use a generic metric hardware torque table if you are not comfortable with the "feel technique".
« Reply #2 on: November 07, 2006, 20:28:25 »
Hello Matt,
Here is a chart for standard SAE and Metric hardware.
http://www.dansmc.com/torque_chart.htm
 Remember your bolt size is actually the diameter or the bolt shaft not the head size! The 10mm head bolt you are dealing with is actually a 6mm bolt size.
« Last Edit: November 07, 2006, 20:29:06 by ja17 »
merrill
« Reply #3 on: November 08, 2006, 07:56:19 »
Joe,
I am looking for the torque to mount the housing to the case not the top of the housing when replacing the thermostat.
I tightened it up to what "felt" snug.  Just want to avoid any leaks.
thanks
matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
