Author Topic: Blocked coolant pipe  (Read 2942 times)
sterl
« on: November 08, 2006, 08:12:55 »
Hello All. Does anybody know how to unblock the U-shaped metal coolant venting pipe at the front of the engine that goes from from the top of the water pump housing to the cylinder head? I've tried poking wire through without success. Thanks in advance.
Mark
Billericay, Essex, UK
Late 67 LHD 250SL
ctaylor738
  • USA, VA, Falls Church
Re: Blocked coolant pipe
« Reply #1 on: November 08, 2006, 14:49:19 »
Soak it in carb cleaner overnight, then blow it out with compressed air.
Chuck Taylor
1970 280SL #14076
Falls Church VA
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
sterl
« Reply #2 on: November 09, 2006, 01:16:26 »
Thanks Chuck. I did manage to clear it with a cycle brake cable and penetrating oil. After 2 hours of gouging it was not only my nerves that were frayed! Anyway, it did work and there was a small sense of achievement...
Thanks again
Mark
Late 67 LHD 250SL
merrill
« Reply #3 on: November 09, 2006, 07:40:26 »
Mark,
how did you know it was clogged?
Matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
sterl
« Reply #4 on: November 10, 2006, 00:45:21 »
Matt, I have the head off and was cleaning everything up. It's very small for a coolant pipe and I thought originally it was an oil pipe. It's probably to help prevent air locks, but I'm not sure. Anyway I just thought I'd check it and it was badly clogged. The head's never been off before so there's 40 years of crud build-up in it. Bet other's have the same problem!
Does anyone know what effect a blocked pipe has?
Mark
Late 67 LHD 250SL
