Glennard,
well, tried the richness test, 3 times on my 66 230 sl today.
1. just disconnected the linkage, the rpm's went to almost 2000
2. motor off, turned screw ccw on the inj pump, tried again, 1400 rpm
3. motor off, turned screw cc4 on the inj pump tried again, 1100 then a stumble.
I noticed that if I rotated the linkage arm slowly I could maximize the rpms.
from the last test, checked the co% with my gas tester. at 875 rpm it was 5 - 5.8%.
then the trouble started, the car would not start, I think the inj pump was too lean, before the adjustments the car ran great.
so I wonder if the motor is just worn and needs to be rich OR does this indicate another issue??
I am embarrassed to say the mixture screw on the inj pump was probably turned 8x ccw.
I turned the screw cw x4 but the car would not idle, so back to the drawing board. I should have made note of exactly how many times I turned the screw ccw.
matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
