Rodd,
Yes that is absolutely correct, but in this case the brakes are not boiling over or hot. Just a long straight drive without braking and then the pedal lacks feel till all the way to the bottom. I have put the back of my hand to each wheel to feel the heat and all are reasonably cool/warm.
Might be the vacuum pump is overboosting the vacuum. I will try another larger *booster to see what happens.
*note: I think this is a conversion problem with some incompatible parts. Besides all the parts coming from MB's, but the booster is from a W124 series, the MC and engine with pump are W201 series. Think I'll shoot for a W201 booster to see what happens.
Walter
1967 220SL-diesel
