Author Topic: Brake Dust on Rims  (Read 5044 times)
harleydan
Brake Dust on Rims
« on: November 16, 2006, 09:41:59 »
a. What have people done to successfully minimize/mitigate brake dusk from getting on the rims or to stop brake dusk from cloning itself to the rims?
b. Once brake dusk has firmly attached itself to the rims (those unsightly hard to get off spots), how does one take it off without harming the rims?
c.  I get much more brake dusk on my rear rims as compared to the front ones.  What is the cause and is this normal?  I have disc brake all the way around.
Danny
1970 280SL silver Euro manual with some brake dust on the rims
Re: Brake Dust on Rims
« Reply #1 on: November 16, 2006, 10:12:06 »
a.  I don't try any preventative measures.
b.  Standard wheel cleaner from auto part store that says "safe for painted wheels".
c.  I have drums in the back, but I believe your system should have some regulator or compensator valve (can't recall proper name) that permits more pressure to the front.  That may be defective.  One member put an adjustable valve in his Pagoda so play with various pressure settings to the rear brakes.
Khurram Darugar
« Reply #2 on: November 16, 2006, 11:14:07 »
Danny,
      Although I have not used them myself, EBC makes break pads that are supposed to be either low dust or dust that clears away easily.  I believe they also do W113 break pads.
http://www.ebcbrakesdirect.com
Kay
Kay
Euro 280sl LHD Auto.
« Reply #3 on: November 16, 2006, 16:09:00 »
I believe the amount of brake dust on my front and rear wheels (well, hubcaps) is about the same, although on most other cars I've ever owned the front wheels usually get a lot dirtier than the rear. Does your car suffer from the typical 'nosedive' upon hard braking? Do you feel the brakes are not very effective? Then there is probably an issue with the brakes that you should (have) look(ed) at.
« Reply #4 on: November 16, 2006, 16:44:55 »
Do your wheels have the "pie tins", after marker dust shields on the front and not on the back?
Just a thought.
Al
66 230sl
113-042-10-014715
904/396 blue, Ivory Tex
harleydan
« Reply #5 on: November 16, 2006, 18:13:16 »
Cees...Yes, I suffer from "typical" nosedive during hard breaking.  I hope to minimize it by getting the John Olson springs.  I already got new shocks (Bilsteins) all around.  I would say that my brakes seems fine, but I have not compared it to another W113.  When I do get the new springs (which hopefully should be arriving soon), I will also have ceramic break pads and braided brake lines installed on the four corners.
Al...I do not have any pie tins on the front nor the back.
Danny
glcg123
« Reply #6 on: November 16, 2006, 21:51:20 »
My experience with brake dust on any car with disc brakes is that if you wash the wheels regularly by hand or with a wand wash then the dust is easy to remove and the wheels will always look clean. However, leave it a few weeks and it bakes on.
Some cars are worse than others and it is a function of the wheel design. Any car with turbine type wheels are harder to clean and keep clean.
One other point about regular washing of the wheels, drive the car and use the brakes a few times to evaporate the water. They have a tendency to flash rust which can cause some binding/sticking in the piston area cauisng premature wear of the pads.
George
1965 230SL 4 speed
« Reply #7 on: November 17, 2006, 07:46:23 »
I am sure I read somewhere that a spray of WD40 on the clean wheel prevents the dust from baking on as badly next time
Not tried it myself but it may be worth a google...
dreyer635
« Reply #8 on: November 17, 2006, 14:17:59 »
If brake dust is a problem - check if EBC can deliver "green" pads  - I have not tried that om my Pagoda, but my BMW 635 the rims are very cleen after mounting the EBC pads - even when running hard.
