Author Topic: Parts Help! AT sending unit/switch  (Read 2735 times)
dwsfca
« on: November 28, 2006, 18:49:21 »
I have been trying all the usual online parts houses but have not been able to find what I thought should be a readily available part.
I need the sending unit or pressure switch that is activated by fluid pressure when the trans is placed in gear, which in turn connects the constant speed soleniod to ground and activates the solenoid. (whew!)
I think I have found a MB part number 001 541 13 17 but I cannot find anywhere to verify this number.
Anyone have a suggestion?
Dan
Re: Parts Help! AT sending unit/switch
« Reply #1 on: November 28, 2006, 18:55:59 »
yes it is the correct number
There is a seal ring you might need. It seals a line that goes to the pressure switch
N 007603 012405
merrill
« Reply #2 on: November 28, 2006, 18:59:05 »
Dan,
try
  SUN VALLEY MERCEDES DISMANTLERS, INC.
 Used Mercedes Parts    Remanufactured automatic transmissions
11203 Tuxford Street
Sun Valley, California  USA  91352
Phone: (818) 7680704   FAX: (818) 7680526
http://www.mercedesdismantlers.com/
or sls
http://www.sls-hh-catalogue.de/bin/dbframes.phtml?mid=IN01
if sls has what you need, it can be ordered thru cheryl at K&K
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
KevinC
« Reply #3 on: November 30, 2006, 05:47:10 »
I purchased a new one from SLS two months ago...about $80.00 [:0]as I recall.
Kevin Caputo
Boca Raton, FL
1967 230 SL Automatic
670 Light Ivory
113 Bronze/Brown MB Tex
