Author Topic: King pin polishing?  (Read 2020 times)
Jazn
King pin polishing?
« on: November 29, 2006, 10:35:54 »
When I brought my spindles and king pin to the machinist to be reamed, he noted the new king pin was rather rough were it would be in contact with the brass sleeves.  Is this normal?  He recommended polishing them, should I?
JimVillers
  • USA, VA, Virginia Beach
Re: King pin polishing?
« Reply #1 on: November 29, 2006, 18:58:21 »
The king pin surface should be very smooth.  Cleaning off the surface corrosion with steel wool should be enough.  It should not need to be "polished".
Jim Villers
Jim Villers
