See if this is better
Download Attachment: fuel.jpg
39.6 KB
Thanks, that's a lot clearer. I also took a look at blairwag's picture on a better monitor, and I was able to distinguish the two tubes as they went into the valve unit, so I should be OK as long as his hookup is correct. As I see it, if you look down on the valve unit with the tube to the vapor tank on top and pointing toward you (like in Blair's picture), then the right tube goes to the inner line on on the trunk (manifold), and the left line goes to the outer line in the trunk.
From your diagram, it looks like if I were to suck on the line that goes to the vapor tank, then I'd feel a little suction from the line that's supposed to go to the outside vent (the outer line). I'll see if I can verify this if I can do it without messing up any of the tubes.
Bruce
1971 Copper 280SL Automatic
