Author Topic: Lifting a 113 for inspection - how not to??  (Read 2290 times)
jameshoward
« on: December 02, 2006, 15:52:57 »
Hi All,
I was wandering about the internet and came accross this ebay item. The item itself is of little interest; however, I read with interest the 'advice article' posted in the item (please scan towards the bottom of the item ad to find it) which states, I believe, that the car should only be lifted on a ramp-type vehicle lift given the stress loading on the front suspension. Is this entirely correct?
http://cgi.ebay.com/Front-Subframe-Repair-Kit-Mercedes-W108-W109-W111-W113_W0QQitemZ200052606092QQihZ010QQcategoryZ72454QQrdZ1QQcmdZViewItem
JH
James Howard
1966 LHD 230SL
Re: Lifting a 113 for inspection - how not to??
« Reply #1 on: December 02, 2006, 19:06:29 »
What he is trying to say is if your frount subframe mounts are old you run the risk of tearing them by putting the car on a pad style lift. Basically if you are driving a 40 year old car it might be a good idea to replace the mounts so you will not face this problem.
When I first bought my car I put it up with the engine running trying to find a transmission leak and the mounts were torn. Needless to say the racket of the fan hitting the shroud put a stop to that.
