Author Topic: Bosh horn repair  (Read 3233 times)
joelj
Bosh horn repair
« on: December 04, 2006, 08:26:16 »
Hello group,
Is it possible to repair the bosh horn of our pagoda? Mine seems to have gone kaput B( If it needs to be replaced what is available out there? Can we still get these old horns?
Joel
1969 280sl auto
White exterior
Blue interior
dreyer635
Re: Bosh horn repair
« Reply #1 on: December 04, 2006, 11:41:38 »
I took mine appart due to almost no sound - cleaned dirt and rust from them and resprayed with black paint. Went over the eletrics and made shure there was a good connection. They both worked 100% when I put them together again. You can also get new ones, SLS have them for about €60 each, but since this is fairly simple electronics you should be able to make them work again. Check with a ohm meter that the solonids are working. Also remember that this is a two tone horns, each marked with the individual frequency.
Kjell
Sl 280
Norway
« Reply #2 on: December 04, 2006, 13:35:54 »
http://index.php?topic=3197
http://index.php?topic=2871
