Author Topic: Correct Coolant?  (Read 2812 times)
dschuett
Correct Coolant?
« on: December 06, 2006, 16:37:53 »
My mechanic states he uses Prestone in everything.  Other Pagoda owners insist that Mercedes Benz branded coolant is a must to preserve the integrity of the aluminum head.
Anyone have experience with this issue?
Thanks.
Dale Schuett
1971 280SL Dunkelrot
Dale Schuett
1971 280SL Dunklerot/Black
carguy5105@aol.com
« Last Edit: December 07, 2006, 15:13:34 by rwmastel »
JPMOSE
  • USA, DE, Harbeson
Re: Correct Coolant?
« Reply #1 on: December 07, 2006, 07:02:07 »
Dale,
You may want to ask this question on the discussion forum.  I do know that Prestone has reformulated their antifreeze to be usable in all systems.  However, I will probably go with Mercedes since it is only a few dollars more and everyone praises it so much.  I would also use distilled water when refilling, as it is inexpensive and good insurance too.
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
