Author Topic: Paint Under Rocker Covers  (Read 2123 times)
« on: December 16, 2006, 07:14:20 »
Happy Holidays!
 :?: Question: Was the black paint under the rocker panel covers (area between the bottom of the covers and the underside) brushed on?  As I look at my car, and pictures of others, this looks like another area where the paint was brushed on?
Is this correct?
Thanks!
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
Re: Paint Under Rocker Covers
« Reply #1 on: December 16, 2006, 18:31:15 »
To my knowledge there is a rustproofing material applied, similar to 5200. It sets up to a semi hard consistency. It's a urethane rubber that requires mixing in a catalyst. After it sets, black paint is sprayed over it. You can remove the layer of paint with acetone and probe the sealer with your fingernail. There should be very good adhesion of the rustproofing. If there isn't, the metal has rusted. Repair is to sandblast to a white finish, apply phosphate based metal prep (phoshoric acid), dry well and then apply the 5200.
