Author Topic: Fuel filter part nr.  (Read 4197 times)
rwaw
« on: August 17, 2003, 12:50:29 »
Does anybody have the correct part nr for the fuel filter (280 1969); my regular parts supplier keeps sending me one with parts nr A 000 092 54 05 (made by Hengst).
This does not fit; when I took the original one out it had a number like this: A 000 092 [b]2?7?[/b] 05 (made by Knecht).
I am not certain about the "27" !
Of course I forgot to write this down and would now rather not remove it again just to find the correct nr to reorder.
Thanks for your help.
Re: Fuel filter part nr.
« Reply #1 on: August 18, 2003, 04:00:26 »
The online K&K Catalogue shows this number 000-477-64-15
You can see it at http://www.kkmfg.com/
They use corect MB numbers.
I think it is a kit including a new seal.
Bob(Brisbane,Australia)
« Reply #2 on: August 18, 2003, 21:30:42 »
Hello rwaw,
Two manufacturer numbers for the fuel filter are Knecht #EK402 (Austria) and Mann #P707 (Germany). The rubber o-ring seal is usually not included with the filter.  If you use a new seal it may keep falling out of the groove, you can use some chasis grease to hold it in place while the canister and filter is installed.
« Reply #3 on: August 21, 2003, 04:43:41 »
Raoul,
The merc part # is 000 477 6415 which is the same as Mann P707 paper element filter.
'Kloines Scheisserle'
« Last Edit: August 21, 2003, 04:56:46 by naj »
