Author Topic: Help with wiring  (Read 3513 times)
Help with wiring
« on: December 21, 2006, 22:32:47 »
Hello all you electrical specialists,
please help me figuring out where the wire in this picture goes to:
Download Attachment: Unknown_wire.jpg
75.14 KB
It is a grey wire that comes out of the harness together with several others that attach to the alternator (generator).  One possibility is that it goes from the ignition switch to the starter .. but if correct then according to Achim's wiring diagram this should be a "violet" colored wire.  Could the color have changed that much in 40 years??  Keep in mind, however, that these wiring diagrams are a lot more confusing to me than the Paris Metro (or London subway) maps, I may be completely off base here.  :(
Re: Help with wiring
« Reply #1 on: December 21, 2006, 23:01:15 »
Yes that is the starter wire, My purple wire had faded to that same shade of grey.
If your starter has been replaced with a SR59x the wire needs to be attached to the smaller of the 2 screws on the solenoid.
Al
66 230sl
113-042-10-014715
904/396 blue, Ivory Tex
« Reply #2 on: December 22, 2006, 12:00:07 »
Thanks Al,
and especially for your ESP!
I do have the newer SR59X, and that would have been my next question.
« Reply #3 on: December 24, 2006, 18:25:29 »
Alfred,
How was the car starting without the wire attached?
« Reply #4 on: December 26, 2006, 10:14:01 »
Haven't you watched the movie Little Miss Sunshine  :?:  http://www.apple.com/trailers/fox_searchlight/littlemisssunshine/
You always stop and park downhill and then just push  :)  :D
« Reply #5 on: December 26, 2006, 10:26:24 »
My first car a 62 Spridget worked like that.
Al
66 230sl
113-042-10-014715
