Author Topic: how do you change the F.I. oil etc....  (Read 8184 times)
erickmarciano
  • Canada, Quebec, montreal
« on: August 18, 2003, 20:34:20 »
just got the car and waiting for the big blue book
what oil does the manual Transmission take?
and the Differential oil ?
and the F.I. Pump oil ? and how do you change it?
thanks
erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: how do you change the F.I. oil etc....
« Reply #1 on: August 18, 2003, 20:53:33 »
Eric,
Congratulations on your purchase!  My best advice is to use the search tool for the forum, it works well.  Not only can you get answers to your questions, but you will always learn something tangential to your topic.
I don't know about particular brands:
- Manual transmission actually uses automatic transmission fluid
- F.I. pump is fed engine oil through a line - no maintenance
- Differential is 90 weight hypoid gear oil unless you have a limited-slip diff.
This is all from memory from reading other people's posts.  It sounds like you need an owners manual to go along with your BBB.  I also highly recommend the Haynes manual and most importantly the MB Spare Parts List book.  Also, depending on the version of the BBB you get, it may not have all info in it.  Some jobs were only printed in the early manuals (for the 230SL) and not included in the later version.
I hope you really enjoy the "new" car!
1966 230SL Euro
erickmarciano
« Reply #2 on: August 19, 2003, 09:21:36 »
how do i know if i have a limited slip diff?
how much engine , trans , diff do i need ?
i am still waiting for my manuals
thanks Erick marciano
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #3 on: August 20, 2003, 06:32:31 »
Your data card would tell you if you have a limited-slip (I don't know the option code, but it's in our database).
I would say you need one of each!   :D
I have a 230SL, so this might be different for a 280SL, but my diff takes about 2.5 quarts of oil.  Basically, you fill it until it comes out the fill hole.  My engine takes about 6.5 quarts of oil when changing the filer too.  I have no idea how much transmission fluid you need.  Don't forget to flush/fill the brake fluid.  I have read that you can flush the power steering fluid.  There's also the coolant to change.
1966 230SL Euro
tuultyme
« Reply #4 on: August 20, 2003, 06:44:16 »
Only fill the diff when the car is on the road wheels not with the car up on jacks or you will over fill the rear end.
Bruce; Green 1970 280SL.
« Reply #5 on: August 20, 2003, 07:45:23 »
Bruce, you mean with the car level right? Extended wheels can't change the volume of the the differential can it? How can that be?
Rudy
Los Angeles
1971 280 SL
erickmarciano
« Reply #6 on: August 20, 2003, 10:56:44 »
where do i find a data card for my car
1966 230SL Euro
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #7 on: August 21, 2003, 06:29:49 »
I did a search for "data card", using the exact phrase, and found this thread:
http://index.php?topic=434+card
1966 230SL Euro
« Reply #8 on: August 21, 2003, 14:55:23 »
Rudy, (jumping in here for Bruce)
the differential should only be filled with the rear axles straight, not drooping, as if the car were sitting on the rear wheels.  If the axles are drooping, diff oil runs down into the axle tubes, resulting in overfilling.
I use a pair of ramps to raise the rear of the car for this, since the weight of the car stays on the wheels and the axles stay straight.
Not sure if the entire car should be level, I just raise the rear of the car.  My ramps are only 5-6 inches high, so this probably doesn't make much difference.
« Reply #9 on: August 22, 2003, 03:55:44 »
Gearge,
I think the car is meant to be level when the oil is checked. If you raise the back end, it will show a lower level, resulting in overfilling??
'Kloines Scheisserle'
« Reply #10 on: August 22, 2003, 07:37:35 »
That is so odd George. I would never imagine a design where oil could run into the axles. These truly are amazing cars. I guess people who are more familiar with Mercedes don't find these little quirks discussed on this forum fascinating, but I do.
Rudy
Los Angeles
1971 280 SL
« Reply #11 on: August 22, 2003, 07:38:24 »
Rudy
Los Angeles
1971 280 SL
« Reply #12 on: August 22, 2003, 14:44:05 »
I'm assuming it's bad if oil runs down the axle?
- Why isn't there a seal?
- What bad things happen if it gets in there?
1966 230SL Euro
