Author Topic: engine cut out  (Read 3105 times)
gnj588d
engine cut out
« on: December 27, 2006, 15:48:22 »
My 66 230SL cut out while on a short run on christmas eve it restarted after a few turns,when I got home I took the distributor cap off to check for a good spark all seemed well but when I lifted the points again a big fat spark jumpted from near the condenser to the distributor body,could it be a faulty condenser or broken insulation.Any help would be much appreciated
                Best Wishes from Liverpool
                  Mike Rutledge 230SL SL320
 e        e
Re: engine cut out
« Reply #1 on: December 27, 2006, 21:06:05 »
Hello Mike,
The lug going from the points through the side of the distributor then to the condensor and coil, must be insulated where it passes through the distributor. Often times the plastic insulators have degraded and cause a short circuit. The 7mm lug should have an insulator on both sides of the distributor wall and a insulating sleeve as it passes through the distributor wall.
If you contact a Bosch outlet they may be able to order any parts you may need. Here is a breakdown and a Bosch number which may help.
Download Attachment: distrib.jpg
69.54 KB
Also make sure the "fork" wire end of the ignition points has not rotated close to the breaker plate, or a short may result.
If these are OK my next guess would be the condensor.
« Last Edit: December 27, 2006, 22:12:44 by ja17 »
gnj588d
Re: engine cut out
« Reply #2 on: January 02, 2007, 15:28:40 »
Thanks Joe.will check out your suggestions,
                              Thanks Again Mike Rutledge
