Author Topic: Odds and ends  (Read 4602 times)
Odds and ends
« on: January 21, 2007, 17:22:31 »
I was under the car today and have a variety of small questions (thus the thread). Here we go:
1. The steering shock. What does this do and how long do they generally last? How difficult to replace? While my regular shocks are newly replaced -- this one is easily 44 years old. What might symptoms be of a shot one?
2. The connections and wires on the driver's side of the auto trans. Are these the ones that help dictate the shifting smoothness? Is it wise to disconnect them and clean the crud off the connections? Any dangers in such a move?
Re: Odds and ends
« Reply #1 on: January 21, 2007, 21:56:49 »
If I recall the wire connections on the side of the tranmission pan are the terminals of the three position solenoid on the top of the tranmission. The nueatral safety connections and the reverse light switching is done at the nueatral safety switch on the firewall.
Re: Odds and ends
« Reply #2 on: January 23, 2007, 03:29:15 »
The wires have 3 different size lugs attached to them and on the terminal block there are 3 different sized screws that correspond to the lugs, so large lugs are held on by large screws etc.
So in reality it should be easy enough to remove the wires and clean to your hearts content then re-assemble.
Maybe you could group the wires on each terminal before removing the screws.
Abbas
Re: Odds and ends
« Reply #3 on: January 24, 2007, 12:01:58 »
James,
  If you feel your steering returns smoothly without any delays or disruption after you make a turn, then the steering damper does not need to be changed.
Check Dr Benz quote http://index.php?topic=6263,damper
Originally posted by Benz Dr.
Most cars that come in here with over 100,000 miles on them all have dead steering shocks. It doesn't matter what model car either.
I undo one end of the shock and push then pull on it to see if there's resistance against either direction. No resistance or skips in the action and it's no good.
Abbas
280SL W113 1969 Ivory
E280 W124 1995 Silver
« Last Edit: January 24, 2007, 12:02:48 by Abbas »
Re: Odds and ends
« Reply #4 on: January 24, 2007, 12:14:55 »
Thanks Abbas. The steering seems fine. So I think I'll leave well enough alone for now.
And thanks Bob & Joe. If I find I have nothing better to do, I'll wedge myself under the car, squint because of the muck falling in my eyes, and clean-up the connections!
BABAK
  • USA, CA, Valencia
Re: Odds and ends
« Reply #5 on: January 25, 2007, 00:10:16 »
I replaced the steering shock . Its easy and quite inexpensive .
69 280sl dark olive automatic
71 280sl bronze brown
70 280se coupe light Ivory
59 190sl
61 190sl
www.vintageeuroparts.com
