Author Topic: 2 questions 66 230 sl  (Read 3395 times)
merrill
« on: February 02, 2007, 19:06:59 »
so, starting to put the engine bay back together on the 230 sl and I have 2 questions.
1.  how many clamps should the main wiring harness have in the engine bay and where should they go.  I my car only had 4 and they were all on the firewall.  from the photos I found in the internet it appeaars there should be more like 9.
3. on the firewall (one each side of heater core tube passenger side and one to the drivers side of the hood latch.
1 under the coolant reservoir
1. to center from the hole for the speedo cable
1 under the  relays
1 near the voltage relay on the passenger side
2 forward of the subframe mount  on the chassis
2. there is a braided cord connected to the hood release cable.  It is about 4 inches long and appears to bolt to the firewall to the outside of the heater core tube on the drivers side.  some photos appear to have this connected with the main wiring harness clamp to the center of the firewall hole for the speedo cable?
I can post photos if needed.
thanks in advance for the help
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
Re: 2 questions 66 230 sl
« Reply #1 on: February 03, 2007, 15:58:40 »
Well, I think I figured out where the braided cord screws in.
there is a hole away from center where the tach cable comes thru.
I have e-mailed gernold at sl tech on the wiring harness clamps
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #2 on: February 03, 2007, 17:11:05 »
Hey Matt. Mine has at least nine. Pretty much where your list has them.
nick350
« Reply #3 on: February 04, 2007, 06:55:04 »
Hmmm!
two questions you say....let me ask you this. Does having a box of six eggs allow you into the five items or less queue at the supermarket?
1 under the  relays
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Nick350
r107 SL red
merrill
« Reply #4 on: February 04, 2007, 07:28:05 »
nick,
in texas it does, not sure about the uk
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
