Author Topic: help with a little info  (Read 2417 times)
65auto230sl
« on: February 06, 2007, 17:18:25 »
hi all, does anybody know if a cyl. head from a 1967 250e will fit on my 69 280sel engine? thanks in advance. my head is in need of being re-worked and i found one that has been re-done at a good price. thanks again, bo
65 230 sl
DaveB
Re: help with a little info
« Reply #1 on: February 06, 2007, 18:18:29 »
a 250se head won't fit as the bores are different size.
DaveB
DaveB
'65 US 230sl 4-speed, DB190
« Reply #2 on: February 06, 2007, 19:00:10 »
Dave is correct, it will not interchange the coolant passages in the block and head are also different.  Also be aware that an early 280 SE,SL cylinder head will not interchange with the late 280 SE, SL cylinder head. 230SL and 250 SL, SE cylinder heads are interchangeable.
