with our official
Pagoda SL Group logo
from our official partner.
General Discussion
VIN # on front frame member
Topic: VIN # on front frame member (Read 3073 times)
Associate Member
Platinum
February 07, 2007, 10:29:04 »
Anyone know how they stamped the numbers into the front frame rail under the intake manifold? And when in the assembly process they were applied?
Merely want to figure out how I can replicate the stamping on my 220SL.
Currently has nothing there as the frame there has been replaced.
Also can someone steer me to a source for these number punch kits?
Walter
1967 220SL-diesel
Last Edit: February 07, 2007, 13:37:11 by waltklatt
Tom230sl
Re: VIN # on front frame member
February 07, 2007, 15:24:36 »
ok i'll say what everyone is thinking...
it is not a good idea to do that. Leave it be. Re-stamping would be dishonest akin to remanufacturing data plates, re-stamping the aluminum numbers, creating a original invoice or rolling back the mileage.
Only original once.
IMHO
Reply #2 on:
February 07, 2007, 18:08:11 »
Walter
The number stamps I have seen are quite a bit smaller than the numbers on the frame rail. They are available at machine tool supply houses.
Do you still have the old frame rail? You could cut the numbers from the old rail, about 3 inches bigger than the stamped area and weld it to the new rail, grind it smooth and bondo it up to cover the welds.
Al
66 230sl
113-042-10-014715
904/396 blue, Ivory Tex
Inactive
Platinum
USA, OH, Cleveland Heights
Reply #3 on:
February 07, 2007, 20:03:35 »
Tom,
Just had to respond to your post.
Were you referring to Walt's "Original" 220SL Diesel?
Isn't restoring something about trying to make it appear as it did on the day that it left the factory?
Thank god we have finally gotten past the "numbers matching" phase in muscle cars. You are now allowed to stamp a matching number as long as the block is the same casting as original.
Walt,
Most of those numbers are usually a special size and or font to discourage exactly what you are trying to do(keeps the thieves at bay). Short of custom stamps I would leave it the way it is.
Full Member
Platinum
USA, OH, Canal Winchester
Pagoda SL Group: 20+ years and going strong!
Reply #4 on:
February 07, 2007, 22:27:35 »
What number would you use? It's no longer any of these:
113.042
113.043
113.044
I guess my point is why would you worry about this at all on a customized car?
1966 230SL, Euro, Auto, Leather, both tops
General Discussion
