Author Topic: Steering wheels & horn pads Tour  (Read 31828 times)
Re: Steering wheels & horn pads Tour
« Reply #25 on: July 11, 2009, 10:03:53 »
I'm having moulds made of all types from originals, including grooved and non-grooved.
The only difference will be that I haven't bothered with the small holes in the back, although these could easily be drilled if required.
I'm going on holiday on tuesday but will post pictures of the finished article when I return.
« Reply #26 on: July 13, 2009, 21:52:01 »
I have to say that the results have exceeded my wildest hopes!
Not only is the colour spot on but the all-important feel is too.
I'm off on holiday but will post pictures when I return.
« Reply #27 on: July 23, 2009, 21:33:52 »
So, as promised, here's some pictures:
« Reply #28 on: July 24, 2009, 12:01:14 »
These pictures will disappear from this forums as soon as Photobucket kicks the bucket, or drops these files. Please in future Attach pictures to your message using the Additional Options... Upload feature. I will disable the IMG tags otherwise.
« Last Edit: July 24, 2009, 12:04:11 by vanesp »
280sl1968
« Reply #29 on: July 04, 2010, 06:15:48 »
I saw this burlwood steering wheel listed on the German eBay. I assume it is a modern aftermarket wheel and was never available as an original option.
David
jacovdw
« Reply #30 on: July 04, 2010, 08:10:07 »
Your assumption is correct David.
That was never an option from the factory. You basically only had a choice of two colours: ivory and black.
