Author Topic: Fuel Tank Differences  (Read 3570 times)
wit61
« on: February 09, 2007, 20:54:51 »
After searching the archives, I have not found anything on the difference between the 230 tank and the 250/280 tank. Are they  interchangeable ? Thanks
1964 230SL Auto
1972 BMW 2002tii
If you go flying back into the past and you see someone flying forward into the future, it is probably best to avoid eye contact...
Re: Fuel Tank Differences
« Reply #1 on: February 09, 2007, 22:46:44 »
Well, they're different sizes (capacities).  Aren't they 65 liters and 82 liters, or something like that?  I don't know if they're interchangable.  It would be nice to get the larger tank on my 230SL.
« Reply #2 on: February 10, 2007, 02:45:36 »
You can fit the bigger tank in the later 230 SLs with the horizontal spare wheel on the right of the car.
If you have the earlier vertical spare wheel with a wheel well on the left of the trunk, then no!
wit61
« Reply #3 on: February 10, 2007, 07:06:33 »
Thanks. I have the earlier upright spare, so I'll have to find a 230 tank.
1964 230SL Auto
1972 BMW 2002tii
« Reply #4 on: February 10, 2007, 10:11:13 »
Brand new ones are expensive.  How about I sell you my old one that needs cleaning (no leaks, currently, but rust might be holding the fuel in) and I buy a new large tank??   ;)
By "you can fit", does that mean it's easy and simple, or, does it mean if you're a master mechanic and have a whole weekend to spare?
« Last Edit: February 10, 2007, 10:13:19 by rwmastel »
« Reply #5 on: February 10, 2007, 10:30:04 »
Hi, Rod,
I was told by SLS that its a straight one for one swap. Even the old fuel gage should work.
rogerh113
  • Los Altos, Ca
« Reply #6 on: February 10, 2007, 10:51:12 »
I have a '66 and had to replace the fuel tank.  Tried a later model tank, but the filler neck would not fit into the filler neck hole in the body.  Decided not to try and 'bend to fit', because it was off more than a bit.  Ended up getting a new, correct tank for the 230SL, and the fit was perfect.
Roger
« Reply #7 on: February 10, 2007, 16:23:57 »
Even thought it is listed as a 280SL tanl I think this ebay tank is for a 230. Notice the filler on the corner of the tank(verify before bidding)
http://cgi.ebay.com/ebaymotors/MERCEDES-113-230-250-280-SL-230SL-250SL-280SL-GASTANK_W0QQcmdZViewItemQQcategoryZ10076QQihZ019QQitemZ290080849368QQrdZ1
