Author Topic: Ragtop Well Drain  (Read 3474 times)
Ragtop Well Drain
« on: February 16, 2007, 12:42:49 »
I have a '66 230 sl which I'm saving from the depths.
I notices as I was replacing the rocker panels a plastic drain tube hanging down from the ragtop well,the drain tube dosen't seem to have an exit point. Is there a exit point location? Or did this danging drain tube just help in the process of rust?
Thanks, Barlow
Re: Ragtop Well Drain
« Reply #1 on: February 16, 2007, 22:05:30 »
As I remember, it goes into the wheel well.
« Reply #2 on: February 17, 2007, 06:17:33 »
Thank you, I'll try to look at a finished car to see the exact exit location and what is used for a gromet to hold the tube in place.
« Reply #3 on: February 17, 2007, 09:00:48 »
Barlow,
If you insert a thin long rod thru the drain hole. it should show up in the gap below the lower trim
Download Attachment: Wtr_drn049.JPG
20.86 KB
