Author Topic: 250 sl timing  (Read 3162 times)
aeneasm
250 sl timing
« on: February 18, 2007, 14:29:47 »
motor is m129. what is the correct timing marks for this motor,point gap and dwell angle.manual trans
aeneas
mulrik
Re: 250 sl timing
« Reply #1 on: February 19, 2007, 09:45:52 »
I have a 250 SL with the original engine. I use ~0 degrees at idle with vacum on and 30 degrees at 3000 RPM, (where vacum doesn't matter) Points between 38-42 I think or is it 37-41 I can't remember exactly. Gap on spark plugs is 0,9 mm or is it 0,8 ;-) Anyway it sparks.... %CO is ~4%
Let me know if I can help any furhter.
Ulrik
Re: 250 sl timing
« Reply #2 on: February 21, 2007, 06:38:31 »
250sl
timing 2 ATDC +/- 2 at idle with vacuum, BBB says this is the way to set up the 250sl
30 btdc at 3000 rpm
dwell angle 38 -1/+3
CO 3.5-4.5%
points gap 0.012-0.015" or replace points with an electronic module eg Pertronix hall effect, Crane optical, etc
Plugs usually straight from Bosch, w7dc, 0.035"
(I have mine set at 0.040")
« Last Edit: February 21, 2007, 06:43:09 by hands_aus »
