Author Topic: trans bolt pattern?  (Read 3371 times)
trans bolt pattern?
« on: February 22, 2007, 17:17:19 »
I am starting research on a modern 5-speed transnission in a 113 and I am wondering if anyone knows if the M130 engine shares the same bolt pattern as the later aluminum twin cam engine from the 107SL?
cth350
  • USA, NY, Rockville Centre
Re: trans bolt pattern?
« Reply #1 on: February 23, 2007, 14:07:49 »
yep, they are interchangable. -CTH
philmas
  • France, Ile-de-France, Le Raincy
« Reply #2 on: February 23, 2007, 14:42:24 »
What would be the technical challenge of installing such a trans in a 113body? (i.e.shift lever, drive shaft...)
Philippe from Paris
Euro '71 280SL manual 4sp
  • USA
« Reply #3 on: February 23, 2007, 15:23:41 »
Hold on Shvegel,
Be sure you trial fit first.
I tried the original automatic mated up with a 1981 300D automatic motor and they would not line up.  Forced me to buy the tranny that went with the motor.  This was on a 1968 280SEL, with a frozen M130, that I converted years ago from gas to diesel.
So do a trial fit first before buying anything.
Walter
1967 220SL-diesel
  • USA
« Reply #4 on: February 23, 2007, 15:25:12 »
And to anwer your other question on the 220SL.  Yes it has a 5 speed tranny in it, but from the W201 series.  The starter is on the opposite side, drivers side.
Walter
1967 220SL-diesel
« Reply #5 on: February 23, 2007, 17:20:57 »
I am just in the process of buying stuff to put this all together. The driveshaft is easy you just throw money at it. The shifter is a fabrication job but not difficult.
The real problem is mating the engine and trans which will require building a fixture to hold a stock transmission and locate the shaft height etc. Then I will have to remove the stock trans and build a u dapt it kit to mate the more modern 5 speed trans to the M130 engine.
I have done all this before on a variety of projects including helping a friend wedge a V-8 Porshe 928 motor in a 4 cylinder 914 which required a custom adaptor and a vastly reworked flywheel.
« Reply #6 on: February 23, 2007, 19:00:19 »
Walt,
Speaking of the 220SL I wanted to commend your pioneer spirit. Sounds like an interesting project.
Maybe somday I'll get up the courage to drop the 1988 BMW M5(300 hp with a few mods) engine in my SL then I wont have to worry about engine and tranny adaptors.
Of course I'll probably be asked to turn in my grille star
« Reply #7 on: February 26, 2007, 08:55:14 »
Originally posted by Shvegel
If you are talking about the M110 twin cam that came in Euro 107sl's, they have a larger diameter flywheel and bell housing. I tried once mating a 110 motor to a 114 side loader 4 speed when I built my 250PT and ended up changing both the engine and trans from a 116 chassis 280se to make it work.
Al
66 230sl
113-042-10-014715
904/396 blue, Ivory Tex
