My Pagoda has been motionless since it cut out on my driveway last November and has not run since. The engine turns, but makes no attempt to fire. I've been sending and receiving posts about the problem on the MB Club UK website but I thought I would open up the problem to a wider audience. Spring is approaching and I'm beginning to get desperate !
This is the current situation :-
We have fuel at the inlet pipe to the injection pump and also at the return pipe, but not a drop coming from the top of the pump above the rack. As a result, needless to say, the spark plugs are bone dry.
The coil, ballast resistor, points and condenser have been replaced even though we were getting a decent enough spark to the plugs. We obviously can’t set the timing properly until we can run the engine. I’ve no reason to suspect it’s out. We have carefully done a bit of advancing and retarding to no avail, making sure it set back to it’s original position. So I think we have ruled out an ignition problem.
The fuel injection pump that was fully overhauled by Tower Bridge Diesels in 2004, has recently been returned to them and checked out on their test rig. No fault found, apparently working perfectly.
Before removing the injection pump and again after re-fitting, we took the side plate off the pump to check that the pump was being turned and activated by the engine – yes it is.
At the front end of the pump, as recommended, we removed the cover plug, inserted an M5 bolt into the thread at the front end of the control rack and checked it was moving freely – yes it is. We also turned the engine with the rack pulled forward to the maximum fuel position. Under these conditions, a very tiny amount of fuel weeps from the top of the pump outlets.
Next, we checked the operation of the cold start solenoid at the back of the pump. The plunger is popping out as required, presumably to push the rack to the maximum fuel position.
We removed the cold start valve on the inlet manifold sufficiently to be able to see that it was providing the necessary spray of fuel into the manifold – yes it is.
Even though we are getting fuel to the injection pump, we had a look at the electric fuel pump at the back of the car. That did have a leak from behind the plate where the live and earth cables screw on. We tightened the screw holding the plate on and it seems to have cured the leak. We then checked the flow rate from the back. An article that I had recommended 1 litre in 30 seconds. We received half a litre in less than 10 seconds, so that looks ok.
We have even replaced fuses, even though they looked absolutely fine.
To us, everything still points to a problem in the control rack area of the fuel pump, perhaps a major air lock or contamination of some sort.
So, is there a way to prime the injection pump ? Is there any sort of fuel cut off switch that the manuals don’t mention – I can’t imagine so.
In some ways I would like to identify a failed component so that I can replace it in the knowledge that I have cured the problem and it shouldn't happen again. Even if we manage to shift the airlock, I am going to be wondering what caused it and whether it could happen again in a far less convenient place.
We will check the flow rate again because I've now been told that 1 litre in 15 seconds is required. Also, we previously checked the flow rate after we had stopped the leak from the electric pump by tightening the screw holding on the plate between the electrical terminals. It was quite a bad leak. Why would it leak at that point ? What's behind the plate and would you consider taking off the electric pump and having it fully overhauled ?
I'm also puzzled as to why fuel gets through when the injection pump is tested on Tower Bridge Diesel's equipment but not when it's back on my car.
Any suggestions greatly appreciated.
Ian
1998 SLK230
Derby,England
