Since my last post I've checked the screen in the pump and it was clean as a whistle, then I drained the tank again. This time the flow out the tank-to-pump line was like a garden hose until the last 2 gallons, which was barely a trickle. Occasionally, one would hear some gurgling within the tank and then there would be a greater flow for a short time, followed by more trickle. After the tank was empty I blew out both the large fuel feed line (even though I thought from the good flow that it is clear) and the smaller fuel return line with compressed air and cycled 1/2 gallon of gas several times through the tank, allowing it to drain out the open drain plug hole into a pan. This collected a small amount of debris flakes that appear to be varnish, rather than rust. I have not refilled the tank yet. Next?
- Mike Hughes -ô¿ô-
