Author Topic: Water pump lubrication-230SL  (Read 6161 times)
« on: March 17, 2007, 11:31:59 »
Did the early 230SL have the oil lubrication reservoir(90 SAE gear oil) on the water pump?(like the 50s).
Re: Water pump lubrication-230SL
« Reply #1 on: March 17, 2007, 17:45:13 »
Yes, Glen.
The filler plug is on top and the level plug at 3 O'Clock.
Download Attachment: 230wp04.JPG
38.64 KB
« Reply #2 on: March 17, 2007, 22:17:06 »
What VIN did they make the switch?
Originally posted by naj
Yes, Glen.
38.64 KB
« Reply #3 on: March 17, 2007, 23:39:49 »
So is this yet another periodic maintenance task?
« Reply #4 on: March 18, 2007, 06:38:11 »
Rodd,
Yes, if you still have this old style pump with the filler/level plugs. Could  have been replaced with later type 'sealed for life' bearings.
« Reply #5 on: March 18, 2007, 08:51:21 »
Glenn,
Sorry, dunno  :oops:
« Reply #6 on: March 18, 2007, 11:20:05 »
So if we do have one of the early water pumps, what is the recommended procedure for lubing these guys? And, I bet like many here, mine has been replaced over the years. Is it likely that a replacement is the "original" type or would it have been replaced by a "sealed for life" version? My replacement: 115 200 1220
JH
« Reply #7 on: March 18, 2007, 11:41:34 »
As with all things Mercedes the answer is not quite clear on when the change to the different pump was made. Here is the listing of changes I gleaned from the information in the "Mercedes Collector" by Frank Mallory
Chassis 375 - From motor 371 for -0- and motor 005 for -2- water pump changed.
Chassis 5981 From engine -0- 5366 change water pump housing (lower radiator hose changed)
Chassis 6050-14106 From engine -2- 987, modified water pump housing; lowere radiator hose changed.
Chassis 6731 From engine -0- 5987, the water pump received a Kaco packing
Chassis 6736 From engine -2-1157, the water pump received a Kaco packing
Chassis 13640 From engines -0-11122 and -2-3177 the following engine parts were changed 1. crankcase, 2. top dead center timing pointer, 3. ignition cableset, 4. water pump.
Hopefully this give a couple of touch points to narrow down the lubrication change.
I believe the -0- and -2- engine designations refer to manual and automatic transmissions respectively.
« Reply #8 on: March 18, 2007, 13:46:00 »
James,
I believe this is the later pump, but you can check to see if it has the 2 plugs or not ( another excuse to go into the garage....).
« Last Edit: March 18, 2007, 13:48:38 by naj »
« Reply #9 on: March 18, 2007, 16:06:00 »
Naj, I believe you are correct (again!). I don't see any plugs on my pump...
So to tie this to Glenn's question -- good to check and see which style one has. I feel better now.
« Reply #10 on: March 18, 2007, 18:46:01 »
My sept/oct '64(-006576) has a sealed unit-looks original.
