Author Topic: Fuse blows when key turned  (Read 4734 times)
sailjay
« on: March 26, 2007, 19:58:38 »
I've got a frustrating problem in that whenever I turn the key on my #2 fuse blows. Its the stubby fuse for the wipers, horn and lighter. Does anyone have any idea what might be causing this?
Thanks, Jay
1971 280 sl
Re: Fuse blows when key turned
« Reply #1 on: March 26, 2007, 20:06:52 »
When that happened to me, there was a short in the wiring for the cigarette lghter.
PnHi
« Reply #2 on: March 27, 2007, 15:13:16 »
Yep...most likely the lighter.
« Reply #3 on: March 27, 2007, 15:59:38 »
Hey PnHi! Glad to see you are on the radar!
PnHi
« Reply #4 on: March 28, 2007, 06:57:43 »
Hi James.  Been a full member for a year and I scan the forum several times a week and really appreciate the knowledge shared here.  The 250 has been running so well the last couple of years :D I got bored and found a 1970 BSA that I am currently restoring to rider quality.  Hope all is well.
Mike C
Aberdeen MD
68 250SL
Dark Green/Cognac
4sp.
sailjay
« Reply #5 on: March 28, 2007, 16:38:39 »
Thanks for your input. I'll look into the lighter.
Jay
DaCheeze
« Reply #6 on: April 05, 2013, 20:20:22 »
I had a problem after jacking up my SL to replace my tarnsmission mount.  When I jacked it up/down I must have hit the passenger side
horn.  The fuse block on the horn was then much closer to the chassis (or something metal anyway) than before.  Whenever I put the
car in drive or reverse, the engine would shift enough to bring the top lead into contact and short out the circuit.
I bent the horn back into place... took the lead and turned it 180 degrees and refastened.  Problem is now solved.
Strong suggestion.. always check your engine terminal blocks after working under your car.. this drove me nuts for weeks.
