Author Topic: Injector Pump  (Read 36729 times)
Re: Injector Pump
« Reply #50 on: April 18, 2007, 06:04:57 »
Originally posted by Rolf
It worked Bob. I knew you knew it would. Cleaned the points on the relay and it activates the solenoid. I still have that one wire just hanging there. One wire to the solenoid.
Rolf
1966 230SL Auto
1992 300D
1991 FLHS
Rolf,
On some Pagoda models the CSV solenoid had 2 terminals and 2 wires.
One was from the relay and the other was 'brown'? and an earth.
The cars with one wire had solenoids that earthed through their bodies.
If the solenoid works without the extra wire connected I would tape that separate wire up and tuck it out of the way and forget about it.
