Author Topic: SOFT TOP  (Read 3220 times)
Kemal
SOFT TOP
« on: April 07, 2007, 18:11:54 »
Hi All
Beautiful Easter weekend here in London....
Hard top off & out with the soft top , all looking great .
However , how do you all recommend keeping the corners of the canvas down ?
The soft top is under a year old .
Should I make the corners wet / damp & put a weight on it for a while , as its kept
in the garage ?
Mr Kemal Shah
280 Sl Manual 1969
« Last Edit: April 07, 2007, 18:12:30 by kemal shah »
Kemal
280SL
Manual LHD69
Re: SOFT TOP
« Reply #1 on: April 07, 2007, 21:51:20 »
Hey Kemal. I haven't quite figured out how to "prevent" the curl but what I do to correct it is: just before I latch the back of the top, I firmly grip the corner edges and hold them in a reverse curl for a moment or two. This seems to help them get back to level. Hope this helps.
Kemal
Re: SOFT TOP
« Reply #2 on: April 08, 2007, 17:06:06 »
Thanks, I'll give that ago .
Kemal
280 SL 1969 Manual
« Last Edit: April 08, 2007, 17:06:44 by kemal shah »
Kemal
280SL
Manual LHD69
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
Re: SOFT TOP
« Reply #3 on: April 10, 2007, 11:17:48 »
To prevent that curl: When you put the top down, reach in and fold the part that is curled now, down besides the fender well. The reason it is curled, is that it has been laying on top of the fender well and taken a set. You have to lift the top up a bit to do that.
Re: SOFT TOP
« Reply #4 on: April 10, 2007, 15:34:37 »
As the engineer suggests, tucking the corners underneath the frame when storing the top will definitely cure the folding up problem. Takes a bit of doing, and having hands that are not too massive helps. My car had the corners turned up all the way for several years, and just one week of the correct treatment cured that condition.
Kemal
Re: SOFT TOP
« Reply #5 on: April 11, 2007, 03:53:57 »
Thank you
Kemal
280 SL Manual
Kemal
280SL
Manual LHD69
Kemal
Re: SOFT TOP
« Reply #6 on: April 11, 2007, 03:54:41 »
Thank you
Kemal
280 SL Manual
Kemal
280SL
Manual LHD69
