Author Topic: Alternator housing cracked / broken  (Read 8524 times)
« on: April 10, 2007, 00:51:57 »
I ran into an interesting issue: my alternator has a cracked mounting point. How it happened I haven't a clue.
http://www.sl113.org/forums/uploaded/Waqas/200741024439_DSC08739-small.jpg
http://www.sl113.org/forums/uploaded/Waqas/200741023941_DSC08741-small.jpg
Once I loosened the adjusting nut, the little cracked flange piece finally came apart from the alternator body.
http://www.sl113.org/forums/uploaded/Waqas/200741024253_DSC08742-small.jpg
I now need a new alternator front face, with the flange piece intact. (any donors out there?)... My alternator has been working flawlessly...
Once I noticed the crack, I couldn't just let it remain like that. On removal, I noticed some slight cracking in a small cooling hose... Now I've taken apart a whole lot more than I'd intended! (replacing all belts, cooling hoses and gaskets, among other things-- see concurrent water pump housing thread)
I was wondering if anyone else had ever seen this happen? (and perhaps share why it would crack like that? Was it too tight?)
WAQAS in Austin, Texas
« Last Edit: April 10, 2007, 00:53:04 by waqas »
Re: Alternator housing cracked / broken
« Reply #1 on: April 10, 2007, 20:31:44 »
I most likely have some of these lurking invarious places around here, which would love a new home. I will check. The earliest alternators had the aluminum pulley. I also see that you have the short four hole waterpump with spacer (latter cars had long for hole waterpump and no spacer, also used different pulley.
« Last Edit: April 10, 2007, 20:35:06 by ja17 »
« Reply #2 on: April 10, 2007, 23:52:31 »
Hello Joe,
Sounds great to me! I'll have to try and make it to Blacklick this year to personally pick up the part.... and to finally meet you and a lot of other really cool people in the group... good motivation for me.
« Reply #3 on: April 11, 2007, 11:52:02 »
Hello, Waqas
I think there are a couple of reasons why the housing would crack:
1. Its very easy to over-tighten the belt with this bolt system.
2. When you adjust the belt, the bolt/nut moves in a straight line but the alternator moves in an arc. Loosening that small bolt on the alternator allows the big split nut to re-allign itself. If it is not slacked off a bit then I believe it would over stress the housing. Snap  :oops:
« Reply #4 on: April 11, 2007, 19:09:59 »
Hello Waqas,
Found a few of these relics in the shed out back. If you email your address to me I will drop it in a priority mail box and you'll have it by the week end!  ja17@worldnet.att.net
I'll put you down as a "tentative" on the Blacklick Tech Session list for this summer. Hope you can make it. It should be well worth the trip.
Download Attachment: alt.jpg
41.22 KB
« Last Edit: April 11, 2007, 19:11:23 by ja17 »
« Reply #5 on: April 20, 2007, 02:02:55 »
Hello Joe,
I just received the alternator cover plate... thanks so very much! You are a true gentleman. Is your P.O. box address the appropriate one to use for return correspondence?
Also, is there an easy way to remove the big alternator pulley nut? I was thinking I might wrap an old alternator belt around the pulley and grip tightly, and then attempt to loosen the nut... any suggestions?
« Reply #6 on: April 20, 2007, 05:12:48 »
Hello Waqas,
A power impact tool makes quick work of it. However this may not be an option for most, I think your belt idea may work.
Joe
