Hello Matt and Dan,
I see the point Dan and the fellow at Metric are making and I correct my previous post. As noted, the off keys will get the actual cam timing closer but will make the alignment of the cam timing marks off even more! Does not make sense, but true. Do not mistakingly put the off-set key in opposite. If you do the alingment marks will be closer but the actual cam timing will be off even more.!
I guess if you use the off set keys, be prepared to use a dial indicater to do the valve timing.
There is always something to learn here by this group, even for the experienced!
