Author Topic: Exhaust ?  (Read 3666 times)
Exhaust ?
« on: April 12, 2007, 06:07:37 »
Hi All!
Got bored again, so pulled my manifolds off to have them cleaned and powder coated.
My current exhaust system is a mix of stainless and rusted steel[:0].  The down-pipes are rusted steel, while the mid section and end section are stainless.  There is a sticker on the mid muffler “Ansa”.
I want to replace the down-pipes with stainless and make it look as nice as the rest of the system 8) .
 :?: My questions are:
1. Should I go the route of custom bending at a local muffler shop?
2. Should I contact Time Valve or other muffler mfg. and order the stainless down-pipes?
3. Should I just replace the entire system with a Time Valve because I will not be able to get the right fit between the 2 different system?
4.Do I need to weld the new with the old (currently entire system is welded) or can I use a clamp to hold the new down-pipes to the old system?
Thanks in advance for your input and advice!
Download Attachment: Exhaust-1.jpg
44.2 KB
Download Attachment: Exhaust-2.jpg
35.22 KB
Re: Exhaust ?
« Reply #1 on: April 12, 2007, 17:01:47 »
Would a call to Time Valve to see what they recommend be of any value? I have a regular system, so cannot offer what might be fit and cut alternatives. It would seem that the where and how of cutting the existing system would be a question for a local (and trusted) place of business.
Re: Exhaust ?
« Reply #2 on: April 12, 2007, 18:15:01 »
Bob, any trouble getting old pipes off the manifold? I've heard this can be challenging. My front pipes look a lot like yours -- the only part of my system that is original.
Re: Exhaust ?
« Reply #3 on: April 12, 2007, 21:28:10 »
Hello James, Jonny,
I unscrewed the down pipes from the manifolds first.  Bolts were very rusty, but with some "Deep Creep", they came off without breaking.
I then loosened the entire muffler system by removing all of the rubber donuts.  As the system lowered in the rear, it broke free from the manifold, no issues.  I then removed the manifold.  Lastly, to get the muffler out of the engine bay area, I had to remove the idler bolt and swing the arm out of the way.  Also disconnected the steering damper.  With a little maneuvering, got the entire system out from under the car.  At this point if I dont cut the old rusted section off and re-install with new down pipes, clamping it to the old, not sure how I would get the entire system back in again...
What is really needed is a lift to get the car up high.  Too late now that I have the old system out.
I did talk to TimeValve today.  They can supply 2 new down-pipes along with sleeves to connect them to the old system.  I may go this route....?
Re: Exhaust ?
« Reply #4 on: April 12, 2007, 22:18:29 »
Bob, Is 'Deep Creep' better than PB Blaster and/or Liquid Wrench?   Where do you get it?
Re: Exhaust ?
« Reply #5 on: April 13, 2007, 05:58:05 »
Hi Glennard,
Yes, I have used PB Blaster and was a big fan of it, until a friend introduced me to Deep Creep.  Deep Creep seems to be a lot better.  Seems to eat the rust much quicker, and is also clear, not orange!
I bought it at AutoZone, but I am sure its other places as well.
When I put some on my very rusted down-pipe bolts/nuts, I was expecting to have to wait overnight before loosening.  Ended up waiting only ~10 minutes and the nuts came off very easily.
