Author Topic: Rear Axel Ratio  (Read 3677 times)
RBurg
Rear Axel Ratio
« on: April 27, 2007, 11:26:38 »
Did searches for the last 3 hours - unable to find the thread as to where the location of ratio on the rear axel is located - can anyone be of help
Thank You
Ron - Minnesota
71 280SL Tobacco "O GIGI"
97 E420 Silver Mist
Re: Rear Axel Ratio
« Reply #1 on: April 27, 2007, 11:35:06 »
Ron,
see message by jeffc280sl in this topic: http://sl113.com/forums/index.php?topic=256
  • USA
Re: Rear Axel Ratio
« Reply #2 on: April 27, 2007, 11:39:26 »
Ron,
That is a difficult thing to find.
You will need a rag, wire brush, flashlight/droplight.
Lift up the rear of the car, place a chock at opp front wheel, parking brake on, jackstand to hold up car.
Crawl under in the, shine light at the differential, use wire brush to brush off the bottom of the diff  to remove the gunk/dirt/ mud/ crud and wipe clean with rag.  look at the surface with flashlight and find the #'s.
There should be some faint numbers stamped.  Your car I think has the 4:08 rear end.
Walter
1967 220SL-diesel
RBurg
Re: Rear Axel Ratio
« Reply #3 on: April 27, 2007, 11:39:46 »
Thanks - just what I needed
Ron - Minnesota
97 E420 Silver Mist
Re: Rear Axel Ratio
« Reply #4 on: April 27, 2007, 11:41:32 »
Check out the thread "Replacing my 230sl differential":
http://sl113.org/forums/index.php?topic=1642,ratio
In his post (on page 3), Rodd Masteller says "On the lower part of the rear of the differential there should be a small (2 inches) half-circle that is flat and has the ratio stamped into it. It will say 3/75 or 4/08 or something like that."
WAQAS in Austin, Texas
Re: Rear Axel Ratio
« Reply #5 on: April 27, 2007, 11:47:41 »
Wow! THREE replies within 15 minutes! We have better customer service than most commercial help-lines!
Now if only we could make enough money off this... just enough to buy another pagoda!
Re: Rear Axel Ratio
« Reply #6 on: April 27, 2007, 19:05:24 »
Yes, that's where it is on my 230SL, but I believe on the 280SL it's on the left side.
Re: Rear Axel Ratio
« Reply #7 on: April 27, 2007, 20:19:41 »
Hello Ron,
Here is a photo of the location on a 280SL.
Download Attachment: gear ratio location late.jpg
37.4 KB
« Last Edit: April 27, 2007, 20:20:53 by ja17 »
