Author Topic: Caliper & vented rotors  (Read 2610 times)
RBurg
« on: April 27, 2007, 11:53:13 »
Will the vented rotors and calipers out of a 72 280 SEL 4.5
fit a 280SL -71 Also Looking at the rear axel if it is the right ratio.
Ron - Minnesota
71 280SL Tobacco "O GIGI"
97 E420 Silver Mist
Re: Caliper & vented rotors
« Reply #2 on: April 27, 2007, 20:31:31 »
Hello Ron,
Yes the 280SEL 4.5 is the donor car for these parts. In addition, many other misc parts are also usable. Things like the steering wheel, window cranks, steering gear box, tools, wheel covers, horn pad, rear brake calipers, side marker lights, many suspension parts, some dash switches, knobs cigg. lighter, are the same. The heater controls are slightly different looking but work fine in a W113 if needed. Since the 4.5 is a  V-8 engine so very little engine parts are usable. However the electric fuel pump will also work fine but is a later configuration.
