Hey Paul,
When I change the oil in my Inj Pump, I add about 150-180ml and then run the engine and check the level.
Generally I run my oil level at about halfway up the dip stick.
I monitor the level closely because I think there is a leak of the internal oil seal. However the level has not changed recently. I put that down to the fact that I have been using the car quite regularly.
Is it possible that the side cover seal is leaking?
