Author Topic: Leaking power steering pump  (Read 2201 times)
gnj588d
« on: May 02, 2007, 14:11:48 »
Hello to you all.I have a leak from the power steering pump.Its not a lot but after a run there is oil on the floor and it gets blown back on the underside of the engine Iwill keep an eye on the level.My question is whats the best way to fix it and is it a big job to remove it can i buy a refurb kit or new seels or is it a reconditioned unit beckoning. Cheers Mike Rutledge.
PnHi
Re: Leaking power steering pump
« Reply #1 on: May 03, 2007, 12:19:32 »
Try this.
http://www.sl113.org/forums/search.asp?mode=DoIt
Didn't work as I expected.  Go to top of page and click search.  Type in description and you will find much information on the subject.
« Last Edit: May 03, 2007, 12:21:08 by PnHi »
