Author Topic: Things in the dashboard ...  (Read 3108 times)
Chad
« on: May 08, 2007, 23:42:28 »
Originally planning to replace wood trim I ventured into the dashboard, I now find myself becoming braver and more ambitious in my plans.  Reading your posts about the work and how to do it has given me some confidence to attack more projects there.
Wood replacement with Heritage woodworks (didn't want to refinish myself, wood too bad)
Send clock, and instruments out for refurbish (probably Palo Alto unless other suggestions)
Lubricate the wiper apparatus (which works fine but is loud from the joint friction)
Recover vinyl pieces on dashboard (probably will have a pro do this one)
Replace steering wheel with new one and new pad
Clean/grease heater control levers and cables (obtain new original if possible)
Install slimface Becker TR radio and new center speaker
Is there anything else reasonable to add?  I feel reluctant to approach the heater box. How hard is it?
Is there a way to make the fan blower switch not squeak when turned? It doesn't seem to open at all.
This is all frustrating work in tight spaces, but it feels good to finally get around to it. The dashboard and controls are very important to the overall experience of the vehicle.  Improving this portion of the car would likely be appreciated by any owners who have not yet ventured there. I know that if I ever purchase another w113 that I will consider the condition of the dashboard apparatus more carefully.
1967 230SL
« Last Edit: May 08, 2007, 23:56:20 by Chad »
Re: Things in the dashboard ...
« Reply #1 on: May 09, 2007, 04:59:20 »
Hello Chad,
Straying down the contact coil in the heater switch with contact cleaner will quiet the swith and make it operate smoothly. Try Radio Shack for the contact cleaner.
Chad
« Reply #2 on: May 09, 2007, 06:05:25 »
Thanks Joe, I'll try it.
1967 230SL
merrill
« Reply #3 on: May 09, 2007, 07:37:09 »
Chad,
I sent my tach, speedo, clock and center cluster to Palo Alto speedo.
they did a great job cleaning everything up (new chrome, polishing glass)  and making all look and run like new.
I was very pleased with the results.
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
JimVillers
  • USA, VA, Virginia Beach
« Reply #4 on: May 09, 2007, 09:15:57 »
Chad ... If you have the instruments out, replace the speedometer and tachometer cables.  I would also replace all dash bulbs with new bulbs; it will never be easier.
Jim Villers
Jim Villers
