Author Topic: radio aerial  (Read 3443 times)
Bryn Jones
radio aerial
« on: May 09, 2007, 10:57:45 »
I am new to the Pagoda and have just purchased 280SL. It has a nice Becker Europa radio but crap reception as the aerial has been hidden horizontally in the engine compartment. I will have to fit it properly and from photos it seems that the normal location is the right hand front wing. I can't work out how this is done or what the correct location is. Does the lower section of the aerial locate in the  the rear of the front wheel well or into  the footwell of the car?. If it is into the footwell of the car there appear to be structures and pressings that I can feel when reaching up above the footwell that would obstruct the installation. I see from the forum that there was an alternative location on the rear lefthand wing but this does not seem to be the standard.
Bryn Jones
Re: radio aerial
« Reply #1 on: May 09, 2007, 11:19:56 »
Hey Bryn. Not an expert but I believe in my car, I can fish my hand up from the footwell to get to the inside base of the antenna. I recall it being tricky.
Re: radio aerial
« Reply #2 on: May 09, 2007, 12:14:28 »
Originally posted by Bryn Jones
...  I can't work out how this is done or what the correct location is. Does the lower section of the aerial locate in the  the rear of the front wheel well or into  the footwell of the car? ...
Indeed the lower antenna section fits into a compartment in the wheel well that is accessible from the inside.
See: Antenna Installation
And more can be found here: http://sl113.com/forums/index.php?topic=4420
DavidAPease
  • USA, CA, Chico
Re: radio aerial
« Reply #3 on: May 09, 2007, 12:46:50 »
Hi, Bryn,
It doesn't sound like you have a hole for the antenna. Here is a diagram I uploaded some time ago that shows where it goes:
http://www.sl113.com/forums/uploaded/davidapease/2006927233147_AntennaMountingHole-small.jpg
-David Pease
'66 French 230SL
-David Pease
seattle_Jerry
Re: radio aerial
« Reply #4 on: May 10, 2007, 01:53:43 »
Mine has the excellent aftermarket option of the aerial on the rear fender. The beauty of its location is that the failed seal allows water to pour into the trunk. on the upside it has easy access.
Bryn Jones
Re: radio aerial
« Reply #5 on: May 10, 2007, 12:41:09 »
Bryn Jones
Bryn Jones
Re: radio aerial
« Reply #6 on: May 10, 2007, 12:41:56 »
Thanks guys for your replies. They have shed light on my darkness!
Bryn
