Author Topic: Replacement door panel fit problem  (Read 5043 times)
69280sl
  • USA, IL, Elk Grove
« on: May 17, 2007, 15:52:05 »
Our original door panels and kick panels were covered with a vinyl foil, something like the material a beach ball is made of. Replacements from World Upholstery, and probably others are covered with a thicker vinyl like MB Tex. Also, their boards appear to be somewhat thicker. When the thicker material ,is wrapped around the edge of the thicker panel (two layers now),the whole assembly is thicker and difficult to get into the channels at the bottom and front, as well as into the various pinch clips that are used in several places.
I had seen reference to this on this forum and specifically asked WP about it. The response was, "it is not a problem". Well it is a problem, not an insurmountable one, but one that makes a simple job more time consuming and a pain. This is to say nothing of a less secure panel that doesn't fit as far into the "V" shaped channels.
Be aware if you are thinking of panel replacement.
Gus
68, 280sl
Gus
tdun824259
  • USA, NE, Grand Island
Re: Replacement door panel fit problem
« Reply #1 on: May 17, 2007, 19:08:41 »
Gus,
About two years ago I recovered my door panels.  The leather used was thicker than the original stuff.  I used a phillips screw driver with a long shaft and carefully drove the screw driver into the V-Groove channel to make it wider.  It actually didn't take alot of "widening of the groove" to provide space for the new leather panel. It works great and now the new leather nestles nicely into it's new home.  Hope this helps.
Tim Dunagan
1971 280 SL
tuultyme
« Reply #2 on: May 18, 2007, 05:28:07 »
I took a slightly different aproach.  When I redid by door panels I also replaced the boards.  I took a rasp and thinned the entire edge of the board so there is less matrial that needs to fit into the metal grove; besides the board there is two layers of leather that needs to fit.  I did the same when I replaced the carpeted boards that go on the back of the seats.  For the new boards in that case I bought 1/4 ply from Home Depot and beveled the edges some to make a nicer fit.
willsam
« Reply #3 on: April 29, 2008, 19:23:43 »
I know this reply is almost a year late, but hope it will help someone else with door panel replacement.  Recovering the door panels is not an easy, quick job, especially if the boards are changed.  As discussed above, the boards plus thick material make it impossible to get the panel into the chrome channels.  Add to that changing the aluminum top that is riveted to the board and you have a recipe for frustration.  Some handy hints.  Top alum piece that rivets to the board also holds an anodized aluminum finisher with a notch in its leading edge.  This notch has to match up with the chrome piece at the top front of the door where the glass slides up/down.  The alum part riveted to the board has to be in the exact right spot so the board will fit into the channel when covered with material.  If the covered door panel does not fit all the way down into the channel and the top of the door panel is sticking about the felt window cushions, the chrome finisher on the end of the door will not go into place.  If it does not go into place it will hit the chrome cap on the end of the convertible top boot as you close the door.
My panels were professionally recovered with the car in their shop, and it came back to me with ill fitting door panels.  To fix this problem I dry fitted the finished door panels by hanging them at the top but allowing the bottoms to not go in the channels.  Looking at the bottom I saw how much board had to be removed.  I carefully peeled back the leather cover, trimmed the board, tapered the board to a knife edge, and then used a Dremel tool with sanding drum to grind away material from the back of the leather.  I then used blue masking tape and taped the leather to the board and dry fitted the panel, the chrome finisher on the end of the door, and the "C" trim around the door latch.  It took me 4 trys and about 3 hours but I have a door panel that fits about 90% as well as the factory did it.  I have an untouched 280SL with perfect door panels and used it as a guide.
Do not forget to clean the glass runners and channels and lube.  Also lube the window lift, install a new outside mirror at this time and check it fits 100% and adjusts before you install the door panel.  Also install plastic sheet over the door frame to act as a vapor barrier.  Sign you name to the inside of the door panel should you need to ID some obscure part of your car for theft recovery.
