Author Topic: HARDTOP 230SL VS. 280SL  (Read 6858 times)
benadirsapir
« on: June 09, 2007, 23:01:35 »
NEED HELP    IS THE HARDTOP FOR THE 230SL THE SAME AS THE HARDTOP
FOR A 1969 280SL AND WILL IT FIT A 280SL.
             THANK YOU
                GENE B.  1969 280SL
GENE
DaveB
Re: HARDTOP 230SL VS. 280SL
« Reply #1 on: June 09, 2007, 23:10:27 »
Yes they all fit.
DaveB
DaveB
'65 US 230sl 4-speed, DB190
benadirsapir
« Reply #2 on: June 10, 2007, 00:11:29 »
is inside of the hardtop any different?
       thnaks ,
 gene 69, 280sl
GENE
enochbell
« Reply #3 on: June 10, 2007, 06:16:56 »
They are not exactly the same.  The latch and receivers at the B pillar are a bit different: they are interchangeable but it is not a perfect fit. To make it perfect, you would have to swap out the receivers (the chrome soft top hinge covers) to match the early or late hard top you want to use. Some one else will have to offer advice on the front latches, as I know they are also different but I don't know if it matters.
g
« Reply #4 on: June 10, 2007, 06:19:33 »
       thnaks ,
 gene 69, 280sl
GENE
Hey Gene,
Generally there is very little difference between the hard tops of the 3 models, however the 230 sl has 2 levers built into the front to secure the hard top to the windscreen.
The late 250sl and 280sls have 2 removable handles which come in a vinyl pouch and can often be bought off the net.
« Reply #5 on: June 10, 2007, 11:20:35 »
             THANK YOU
                GENE B.  1969 280SL
GENE
also speaking in generalaties, 230sl's usualy have clear glass and 250-280s usualy have tinted.
Al Lieffring
66 230Sl
Jones'n for a new gas tank
enochbell
« Reply #6 on: June 10, 2007, 16:42:33 »
This is a good pic of the latter style receiver, the early one (I still am looking for a pic) does not have the inboard half-circle raised area.
g
Download Attachment: e50f_12.jpg
34.79 KB
