Author Topic: '71 280 SL oil filter replacement recommendation  (Read 5303 times)
blairwag
« on: September 04, 2003, 19:53:12 »
I see a lot of listings on EBay for "New Mercedes-Benz lot of 4 oil filters, manufactured by Mann. The Original Equipment Manufacturer!"
The filter currently in the car is (I *THINK*) a Bosch.
Questions:
Is Mann truely the OEM filter supplier?
Are these filters the right quality?
Is a lot of 4 filter kits with the price of $23.95 a good price?
 {$16.95(US) + $7.00(US) ... assuming I win the bid at $16.95}
Re: '71 280 SL oil filter replacement recommendation
« Reply #1 on: September 04, 2003, 22:24:43 »
Van Dijk lists the filters at $7,50 each. That includes the metal washers and the large skinny rubber ring. The other rubber rings (bottom 2 and top 1) are another $3 but these do not require replacing that often. The manufacturers that I am aware of, that are all OEM, are Hengst, Knecht and Mann. You have to be sure that the filters are the right type of course.
« Reply #2 on: September 05, 2003, 03:14:40 »
Blair,
The correct Mann (Yes, it is OEM)  oil filter part # is H720x.
Older numbers were H720 and H720/2
'Kloines Scheisserle'
