Naj,
so, did a test today, I have the timing at tdc at idle with vacuum on.
vacuum on timing = 0 or tdc
vacuum off timing = 11 atdc
when the motor was off I did connect a mighty vac to the vacuum line for the vacuum advance, when vacuum applied (with the cap off) I did see the linkage and body in distro move.
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
