Author Topic: Auto Trans--Idiosyncracy or Problem?  (Read 2299 times)
« on: June 18, 2007, 05:45:24 »
Last week I was doing about an hour or more of urban, stop and go driving.  Ambient temperature was about 85F+/30C+, which probably made the radiant heat off the pavement even hotter.
While my radiator/indicated temp was fine (above 180 but below the line before the red line, and holding steady) the auto transmission behaved erraticly.  For example, on some occasions, when accelerating from a stop light (hence the stop and go...) it seemed that the engine RPM was going up, the car was going nowhere, and then all of a sudden it kicked in with a chirp of the tires.  In this case it seems like the fluid/torque converter wasn't passing the power.  Other times, the shift points seemed all wrong.  Clearly the auto trans was not happy.
I try to avoid this stop and go in the heat--aside from the car it isn't comfortable for the driver!  But when I do, I'm curious as to whether this is an idiosyncracy of the transmission or some issue yet to be solved?  In normal driving (not extended stop and go)and in cooler weather I don't seem to notice anything amiss.
N.B.  Factory rebuilt less then 10,000 miles ago; just had a fluid and filter change, and it has done it in the past, too.
Ideas?
Mercedes-Benz Club of America
Re: Auto Trans--Idiosyncracy or Problem?
« Reply #1 on: June 18, 2007, 21:13:09 »
Hello Micheal,
My first guess would be that a slide valve is binding in the transmission valve body when the unit heats up.  This is a quess. The clearances are very tight in these units. If this is the case the problem may fix itself with a little more use. Otherwise I would re-torque the valve body the next time you have the transmission pan off.
