Shaf,
You could start by disconnecting the CSV on the intake manifold: just remove one of the wires. It may be stuck open and causing too much raw gas and flooding as you are starting the car.
However, I suspect that is not the problem, because if you have ignited gas and "boom" then you may have a potential valve issue, like maybe ignition is occuring with an open intake valve. I have seen it before when someone who did not pay attention adjusted the valves out of sequence and actually burned a VW to the ground by finally getting it started but...
Check the valves carefully.
Have a fire extinguisher at hand.
g
