Author Topic: transmission leak  (Read 3093 times)
daniel.burns13
transmission leak
« on: June 24, 2007, 10:19:30 »
my 280sl auto seems to have a slight leak from grille under torque converter although looking inside it appears to be running down bell housing wall--any ideas- also do i let it develop or not?
Re: transmission leak
« Reply #1 on: June 24, 2007, 12:01:53 »
It is most likely the torque converter (fluid coupling) leaking where the pump drive flange is riveted to the converter body. Taking the transmission out to just replace the pump seals is a waste of time, you will need to have the fluid coupling rebuilt to eliminate this leak.
Al Lieffring
66 230Sl
Jones'n for a new gas tank
daniel.burns13
« Reply #2 on: June 24, 2007, 12:29:56 »
thanks for that, does this mean the extent of stripdown does not go beyond bell housing area and is it a specialist only job or could a local transmission place tackle it?
