Author Topic: lower right hand trim??  (Read 4288 times)
dendrinos
« on: June 28, 2007, 11:49:10 »
Is there a source for dash trim. SLS has the chunk i need grayed out, and i believe i have read here that it's hard to find.
I am looking for the lower right hand Black trim piece that mounts on the corner and under the glove box.
Any ideas where i can look?
P
280 Sl
Michigan, USA
Re: lower right hand trim??
« Reply #1 on: June 28, 2007, 12:48:03 »
Hey P. Exactly which piece are we talking about? I just looked and am not sure I see a black trim piece on my car.
« Reply #2 on: June 28, 2007, 18:45:23 »
I take it, that it is the piece under the part SLS has numbered as "6". You may want to send them an e-mail and see if they have a source or option. Do you have the piece and need it recovered, or need the whole piece?
Perhaps, MB Classic, Millers, Neimoeller (aka the usual suspects) may have the piece. I just looked at Neimoller, and they show the part as available, go to Gruppe 68 on their web site and see if that is what you are looking for - www.neimoeller.de. I was not able to get to the English translation, but it might be there, or at least a contact number.
dendrinos
« Reply #3 on: June 29, 2007, 05:21:56 »
This would be the black padded trim at knee level on the right corner running under the glove box.
In the SLS diagram of 68a it's located under the piece numbered 6 which i presume mounts on the glove box.
p
280 Sl
Michigan, USA
DavidAPease
  • USA, CA, Chico
-David Pease
dendrinos
« Reply #5 on: July 06, 2007, 05:10:52 »
very close. the one i want is for a 280. also mine has an additional bit that runs under the glove box. perhaps close to a foot more length.
P
Originally posted by DavidAPease
Peter,
Is this the piece you're looking for?
http://cgi.ebay.com/ebaymotors/Mercedes-Benz-W113-230-250-SL-Right-Under-Dash-Panel_W0QQitemZ200126428917QQihZ010QQcategoryZ140720QQrdZ1QQcmdZViewItem
-David Pease
'66 French 230SL
280 Sl
Michigan, USA
merrill
« Reply #6 on: July 06, 2007, 08:20:08 »
Peter,
did you call the mb classic center, they can check mb availability for you.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
enochbell
« Reply #7 on: July 11, 2007, 04:42:11 »
