Author Topic: Fan belt replacement part number  (Read 2887 times)
rob walker
« on: July 04, 2007, 07:57:38 »
Can anyone let me have the replacement part number (halfords equivalent ;) ) for the Euro spec 280SL 1967? as SLS are showing 4 types.
Rob Walker
Spain and Turkey
Re: Fan belt replacement part number
« Reply #1 on: July 04, 2007, 12:44:07 »
Hello Rob,
I believe the V-belt part number from MB is 000-997-8392. I got mine from an aftermarket supplier: ContiTECH AVSX 10x935 (10mm width, 935mm perimeter). I usually also keep a spare for longer road-trips.
WAQAS in Austin, Texas
« Reply #2 on: July 04, 2007, 12:45:56 »
Just to clarify: the belt size I gave is for a car with the alternator mounted at the lower mounting point (either no A/C or A/C compressor mounted at the upper mounting point).
« Reply #3 on: July 04, 2007, 15:01:12 »
Rob, I am not sure of a MB part number but if you use the Contitech that Waqas alluded to, their Online Catalog shows the AVX 10 X 925 as correct for 280 cars up to 12/68.
For 230s, it is AVX 10 X 875. Interestingly, the spare I carry with me is this size (from Ray) but the one on the car is a AVX 10 X 888. A little more investigation shows the 888 is standard on many BMWs. Starts to make sense given that my mechanic is a BMW specialist... Just wonder how many other Bavarian parts he's used! The added length has not seemed to cause any trouble in this case.
« Last Edit: July 04, 2007, 15:01:55 by J. Huber »
