Hello Skyline,
Sorry to have bad news for you. This is a major problem. You have thrown a connecting rod, doing major damage to most of the major lower engine parts. Anything can be fixed, however it would most likely be faster and more economical to replace the "short block" assembly (lower engine assembly). I do not know how difficult this may be in Qatar. In the US we would most likely find a good used engine or go to a rebuilder like Metric Motors for a replacement short block.
This kind of engine failure is usually a result of lack of lubrication. Most likely the engine was run a some point with very low oil. Crankshaft bearing failure followed, the engine may have knocked for a while until the connecting rod broke and was shoved through the block. What your looking at in the picture is a hole in the block and the crankshaft journal without the connecting rod!
Sorry for the bad luck!
